400ex thumb throttle screw problem
Old Feb 22, 2005 | 04:54 PM
warmdye's Avatar
Default 400ex thumb throttle screw problem
I flipped my 400ex over and bent my handlebars. I am trying to replace my handlebars and I can't get the throttle off the old handlebars. There is a small bracket with 2 small phillips screws that hold the throttle to the handlebars and I can't get these screws off. Anybody else have this problem? What was honda thinking putting screws on there, they need bolts. I think locetite was used on these screws during assembly. I sure hate to have to drill those screws out and rethread the holes. When I do get it fixed i'm putting bolts on there. I'm can't get a good grip on the screws with a vise grip. I think i'm gonna try to dremel the head of the screw into a square so I can get a better grip but I have my doubts. Any suggestion are appreciated.
Old Feb 22, 2005 | 08:05 PM
robbls's Avatar
If you get stuck, dremel the heads of the screws completely off. Once the part is off you can use visegrips on the screw stump. It will no longer have any pressure on it and it will likely come out easier.
Old Mar 14, 2005 | 12:31 PM
Hippyhunter's Avatar
Changed out my bars this weekend and those lil screws were no issue....OVER TOURQING the bolt that goes into the triple clamp and Trail Tech Billet was!!!! Snap! Here you go have some threads! DOH!
Old Mar 15, 2005 | 09:17 PM
flynhi250r's Avatar
If they are not two bad Craftsman makes some stuff you put on the end of a phillips swrew driver that helps it grab ahold. This only will work 1/2 the time but it will save you a lot of time and agrivation if it does. If not try screw extractors.
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
