Need a Cam expert please!
Old Feb 23, 2005 | 02:06 PM
Kell's Avatar
Default Need a Cam expert please!
I have milled the head on my little 150cc buggy, that has allowed the cam to be about 1/2 a tooth off (I noticed when I took it apart that it was originally a little off before milling it anyway). Would there be any advantage moving the cam from its now slightly retarded position in the other direction to being 1/2 tooth advanced. It may not be exactly 1/2 tooth off but it is close.
thanks,
Kell
Old Feb 23, 2005 | 02:39 PM
garyc660R's Avatar
A half tooth retarded will slightly shift the power range towards the upper end of the power range.....letting the engine operate more efficiently in the upper rpm range. Advancing the cam will do the opposite. With the shaved head I would recommend you determine how much clearance you have to avoid the engine binding up or worse. Shaving the head and advancing the timing could get you into a possible detonation problem BTW. Shaving the head may make a colder plug necessary.
Gary
Old Feb 23, 2005 | 03:30 PM
Kell's Avatar
Thanks, I'll leave it where it is. I don't have any clearance issues and it runs great, just looking for that extra edge.
Kell
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Elkaholic
Sep 6, 2015 02:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
rjacree
Aug 3, 2015 10:21 AM
carolinabomb
Jul 26, 2015 08:40 AM
