IMPORTANT Jetting Question On Z400
Old Feb 28, 2005 | 10:01 PM
04suzukiz400's Avatar
Default IMPORTANT Jetting Question On Z400
Hey all. I am going to re jet my carb. What do i have to do to be able to get at my carb? its a 2004 z400.
and if i buy the 150 main jet and needle will it run good? I am at 656ft above sea level. I need to know what jet and needle you reccomend.
I have yoshimura slip on with K&N filter, plan on removing air box lid.
Jets
Which Needle???
Old Feb 28, 2005 | 11:06 PM
mucky's Avatar
its easy to get to the carb. loosen both clamps and turn it on its side
what size jet is in it now? a 150 might be a little small
and I wouldnt worry about the needle right now
Old Feb 28, 2005 | 11:19 PM
i am a little new at this please explain.
Old Feb 28, 2005 | 11:48 PM
what all do i have to do to be able to put the jets in? and what jet should i run with my mods?
Old Mar 1, 2005 | 01:15 AM
hondahero53's Avatar
you should buy a clymer manual for your wheeler i am in the process of re jetting my carb with the manual i had my gas tank fenders and carb off in less then fifteen minutes plus you should buy a hole jet kit they tell at what elevation your jet size should be
BUY A CLYMERS MANUAL BUY A CLYMERS MANUAL
Old Mar 1, 2005 | 03:25 AM
warrior226's Avatar
What does Yoshi recommend? I had to put a 165 in with HMF. Like Mucky said 150 seems small
Old Mar 1, 2005 | 09:31 AM
i dont want to go through all the bs of buying the kit, i just want to buy the jet for 5$ and git-r-done. i have a slip on with K&N filter and no lid, what jet to use? looking at mikuni. link is in first post.
Old Mar 1, 2005 | 10:08 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Jetting isn't as easy as buying a jet and get-r-done. It takes a while to get it fine tuned. I wouldn't recommend doing it yourself until someone teaches you some basics first hand, instead of diving into something new and gettin your quad messed up.
Old Mar 1, 2005 | 02:18 PM
Ozark38's Avatar
Can't someone at least give him a good starting point? I'm sure there is someone in here with a Yoshi s/o and K&N with an open air box.
Old Mar 1, 2005 | 07:00 PM
i have a guy that will give me a free jet, what size should i get guys?
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
