blaster fuel screw
Old Mar 1, 2005 | 12:11 AM
bl4cksh337's Avatar
Default blaster fuel screw
alright i will now officially make myself an idiot but i forgot which way to turn the fuel screw to make my blaster idle. I put it in nuetral and it died after about 3 mins and i had no screwdriver and i was definately not asking anyone.
Old Mar 1, 2005 | 12:40 AM
bl4cksh337's Avatar
please respond im just asking which way you turn the screw so that it will stay in idle its running at to low of rpms.
Old Mar 1, 2005 | 12:50 AM
bl4cksh337's Avatar
only reason im asking such a dumb question is because i have never had such an elevation change that ive had to adjust.
Old Mar 1, 2005 | 12:53 AM
AustinONeal's Avatar
well i had some problems with my blaster with the idle thers a system that sits on top of the carb well you have to have it set a certain way to make it idle but if u havent messed with it then down worrie about god its been a while since i messed with it but i think in makes it idle faster and out makes it die out
Old Mar 1, 2005 | 07:53 AM
Shav0's Avatar
There is a idle screw on top of the TORS system on your carb. Turning it in will increase the RPM's at which it idles. There is also a air adjust screw on the carb on the air box side. Turning that in will put less air in the mix, turning it out will lean out the mix.
Old Mar 1, 2005 | 07:55 AM
garrett5462's Avatar
im pretty sure sounter clockwise will raise the fuel/idle....
counter clockwise...my bad
slowgsxr97
Mar 18, 2022 03:40 AM
cdoren
Aug 16, 2015 11:22 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
