blaster fuel screw
alright i will now officially make myself an idiot but i forgot which way to turn the fuel screw to make my blaster idle. I put it in nuetral and it died after about 3 mins and i had no screwdriver and i was definately not asking anyone.
well i had some problems with my blaster with the idle thers a system that sits on top of the carb well you have to have it set a certain way to make it idle but if u havent messed with it then down worrie about god its been a while since i messed with it but i think in makes it idle faster and out makes it die out
There is a idle screw on top of the TORS system on your carb. Turning it in will increase the RPM's at which it idles. There is also a air adjust screw on the carb on the air box side. Turning that in will put less air in the mix, turning it out will lean out the mix.
