250r headlight voltage
Old Mar 1, 2005 | 02:09 PM
bigblock2stroke's Avatar
Default 250r headlight voltage
I can't seem to get the r's headlight to work. Putting the voltmeter on the headlight plug with the engine idling yields around 4V. I thought it maybe was the regulator, but I put a new one on and it didn't change anything. Anyone got any ideas?
Old Mar 1, 2005 | 07:58 PM
Nicname's Avatar
The regulator only holds the current to 12-12.5 volts. At idle 4 volts may be normal depending on the stator, however without the regulator it may produce 50 volts at WOT. Mine popped 100 watt bulbs at 5000 rpms, without a regulator. I would check connections, starting at the headlight and working to the stator or vice-versa. Maybe it's something simple like a bad bulb connection or loose socket wiring.
Old Mar 2, 2005 | 01:33 PM
That's where I'm at. I plugged the light to a 12V battery and it works, so now I am in process of going back and checking continuity. I hate electrical problems, can't see those pesky electrons.
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
Whitelx1
Oct 2, 2015 10:55 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
