Any 05 700EFI's With Bad Water Pump Seals???
Old Mar 1, 2005 | 07:08 PM
Dogboy's Avatar
Default Any 05 700EFI's With Bad Water Pump Seals???
Anyone having problems with leaking seals on the 05 700efi water pump?
I only have 15 hours on the machine, and after it sits for a few days it starts to leak
a small amount of coolant. Start it up and the leaking stops. The hose clamps are all tight so
I'm at a loss.
Thanks.
Old Mar 1, 2005 | 07:41 PM
kodiakkid's Avatar
Yep, i have had mine in twice for the water pump seal and it only had 125 miles the first time and 218 the next. I now have 354 and i noticed a leak again, except this time it was coming from the hose that hooks to the top of the pump, i tightend the crap out of it and no more leaks. I f i were you i would tighten that hose clamp again and see if this helps!!
Old Mar 2, 2005 | 12:28 AM
elkbow's Avatar
no problems here, have 600 miles on the machine so far...
dave
Old Mar 2, 2005 | 12:40 AM
springtuckyn's Avatar
on the 25 hour service I just performed, the upper coolant hose was a little loose and leaking... tightened it up and is fine now. Gonna keep and eye on it.
Old Mar 2, 2005 | 09:02 AM
kodiakkid's Avatar
I think mine was the hose leaking all the time. My dealer is very good to deal with and gets right on top of stuff for me.
Old Mar 2, 2005 | 11:34 AM
sdbowhunter's Avatar
I had to tighten up the hose clamp too and it did leak sometimes after I tightened it up. Really tightened up the clamp and after that it has never leaked. I agree with kodiakkid, check the clamp again and when you see a puddle rub your finger by the connection and see if that is where it is leaking. I'm sure that's your problem.
Old Mar 2, 2005 | 01:50 PM
Dogboy's Avatar
Thanks for the information, I took it back to the dealer today it's under warranty so they
can deal with it. Not to mention this way it generates a paper trail.
Old Mar 2, 2005 | 02:00 PM
kodiakkid's Avatar
True!!
Old May 24, 2006 | 02:33 PM
partteeman's Avatar
My '05 700 EFI is leaking coolant at the water pump weep hole as well. I bought the bike new and from the dealer the coolant hose at the pump was leaking. Tightened it up and all was well until about 350 miles on the bike. Now, I've got the weeping water pump. I also checked the oil and it is a little higher than normal, but does not show any water contamination. Warranty would cover the repair, but I'm in a hurry so probably fix it myself. Couple of other things I noticed on the bike from new was a loose rear diff' drain plug(slight leak), hairline crack in weld on lower rear A-arm to frame mount, and a broke bolt on foot brake mount bracket. Bike has been pretty good so far, only had to replace a front cv boot.
ltrmc02
Aug 22, 2021 02:34 PM
Customer Service #1
May 15, 2020 08:46 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
ScopeZ_
Sep 13, 2015 07:55 AM
