200x spark plug
Old Mar 2, 2005 | 09:17 PM
paulie83's Avatar
Default 200x spark plug
i just got done rebuilding my 200x i bored it and also put o dg exhaust since then when i use the stock plug it runs and then the plug quits working i put in a plug from my friends suzuki 230 quadsport and it runs fine i was wondering if it is bad to run this plug??
Old Mar 2, 2005 | 10:46 PM
haywoodjalikme's Avatar
The plug should be fine, what does the plug look like color wise? white,tan,dark, wet etc etc
Are you still in the process of breaking in the engine?
Jeff
Old Mar 2, 2005 | 11:00 PM
paulie83's Avatar
the stock plug was dark and dry and yes i was still breaking it in when this happened also after the motor gets warm it starts to tick pretty loud i was thinking the valves need to be adjusted what do yiou think?? thanks
Old Mar 2, 2005 | 11:13 PM
Plug sounds good, not lean anyways.
Yeah you could check the valves, thats pretty easy on the 200X.(0.003" or 0.08mm intake and exhaust)
What was all done to this engine during rebuild?
Just bore and new piston? New valves, springs? New cam chain and tensioner? etc...etc...
Rebuilt by you, someone else, dealer?
Jeff
Old Mar 2, 2005 | 11:18 PM
The little oil hole plug was put back in when the engine was assembled right????
It goes on top of the cylinder head between the head and the cover on the right side next to the end of the cam. Sometimes they get lost and forgot about.
I think with out that plug the cam won't get lube.
Jeff
Old Mar 2, 2005 | 11:50 PM
MY86ATC350X's Avatar
hey jeff your right about the plug deal, i think your right it wont lube when my firend rebuilded his 200x he didnt put it in and found out after we tore it apart and the on the left side of the cam which sits on the ring was hella worn out so we had to replace the cam.
but werent exactly sure if it was that, because we used the same old cam.
Old Mar 3, 2005 | 12:20 AM
KNOWSALOT's Avatar
The Facility
Spark Plugs are designed to be the weak link in the ignition.
If your plug doesn't run well and the plug from your friends bike runs fine, your plug is bad. Simply put.
Both machines carry the same plug other than the heat range. Your's carries an 8 while your friends is a 7. Other than that, they are the same plug.
And while on the topic of plugs, stay away from the Champion brand if that happens to be the one you are running. I have no explanation as to exactly why...but that brand does not do well in any ATV application and never has.
My suggestion?? An NGK DPR8EA-9 or a DPR7EA-9
If you still run into problems after swapping plugs, you either have a jetting problem, a cold starting procedure problem, a leaking needle valve, or a valve adjustment problem........which is likely due to the ticking noises you are hearing at operating temps.
Adjust your valves to be on the safe side......put in one of the plugs I mentioned (NEW!!)....and go from there. If problems persist afterwards, check the color of your plug and post back. You could have either a jetting problem or a needle valve that is worn.
Keep us posted.
Old Mar 3, 2005 | 08:24 AM
Yup I read too fast again!!!
I thought in Paulies first post he meant 'his' plug worked ok in the friends quadsport.
Gotta get more sleep[img]i/expressions/face-icon-small-blush.gif[/img]
Jeff
Old Mar 3, 2005 | 09:02 AM
paulie83's Avatar
hey thanks for the response i am going to pull the the plug this morning and see what it looks like after riding yesterday i rebuilt the motor just bored it and put in new piston and rings and gaskets im not ure about the oil plug i dont remember seeing it so maybe i should take it back apart and look to see if it is there?? thanks
Old Mar 3, 2005 | 09:07 PM
paulie83's Avatar
hey i adjusted my valves today and the tapping is a lot less still a little bit of noise is this normal?? thanks
