86 TRX200SX axle
Old Mar 3, 2005 | 12:30 AM
undersole's Avatar
Default 86 TRX200SX axle
Any ideas which, if any, other model Honda axles will fit the '86 TRX200SX? I can't seem to find any used on eBay for this model and I hate to spend a pocket load of cash for this old hill climber. Thanks--[img]i/expressions/face-icon-small-blush.gif[/img]
Old Mar 3, 2005 | 09:36 PM
JLmissouri's Avatar
You might take a look at the atc 250sx, they may be the same. Is the drive shaft off to one side, or right down the middle?
Old Mar 9, 2005 | 01:02 PM
undersole's Avatar
The chain sprocket is to the left of center when viewing from the rear of the 4 wheeler.
Old Mar 9, 2005 | 11:38 PM
JLmissouri's Avatar
Thats the same as the 250sx atc. I bet that that would be a good rear to look at. The 200es Bug Red atc is also shaft driven, but it is right down the center. Hope that helps
Old Mar 15, 2005 | 12:52 PM
nakedicarus's Avatar
Uhh... The '85-'87 ATC 250SX's had a shaft drive, and the '86-'88 TRX 200SX's had a chain drive.
Am I missing something here?
Old May 9, 2005 | 12:24 PM
undersole's Avatar
Whoa-
Maybe I should've made a note that the axle is for a chain-drive. Apparently the previous owner had a problem with the hubs and thought it would be great to weld them on. Hence, I can't repair the brake or change the sprocket.
Thanks-
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
