gas line
Old Mar 3, 2005 | 04:17 PM
yamaharaptor350's Avatar
Default gas line
i have to drain my gas tank and i cant get the damn gas line off the carb. Has anyone ever took there gas line off before? how did u get it off the carb?
Old Mar 3, 2005 | 04:45 PM
maddog56's Avatar
Default gas line
Should be pretty easy. Just remove the clip and slide the line off. You really dont need to take the line off the carbs though, you can just remove the line from the other end on the gas tank petcock. Same setup there, clip and pull it off. Neither should be difficult.
Old Mar 3, 2005 | 05:00 PM
Semms40oz's Avatar
Default gas line
Looks like you are even further north than me and if your temps outside are anything like mine then getting that line off might be tricky. If you aren't working in a heated garage you may want to use a hair dryer to heat the gas line a little. those line become impossible to remove when its well below freezing outside.
Old Mar 3, 2005 | 05:05 PM
maddog56's Avatar
Default gas line
You could always cut it off if you have to, and replace it. You can get nicer line and get it longer so that you dont have to remove the line when you move the tank. I've spent a lot of time jetting and its a pain pulling that gas line over and over again. Much easier to just get a long gas line and put the tank where the seat sits.
Try needlenose pliers, worked great on mine.
Old Mar 3, 2005 | 06:04 PM
NBake's Avatar
Default gas line
i had to take it off yesterday, it was a b*tch. the first time taking it off is the worst, but after that its easy. jus take a flat blade, open the clip wit one hand and push at the edge of the fuel line wit the other until it slowly slides off.
Old Mar 3, 2005 | 06:08 PM
Default gas line
yeah i got it with a pair of plyers and just yanked it and it loosened up then pulled it the rest of the way
Customer Service #1
May 15, 2020 08:46 AM
Mar 21, 2016 06:30 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
