Raptor Help
Old Mar 3, 2005 | 06:14 PM
redwingsrule05's Avatar
Default Raptor Help
I was installing a skid plate on my 04 Raptor today and to do so had it in the air resting on the rear grab bar.
I know that the carbs probably flodded while doing this but after starting it and running it for some time it still bogs down and dies when you get on it. It also has an irradic idle. Any Suggestions?
Old Mar 3, 2005 | 06:30 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default Raptor Help
check your air filter
probably soaked with fuel,,,,causing you to run rich
be sure to shut off the fuel when you tip er up
maybe even drain the bowls if you dont want it running all over the place
Old Mar 3, 2005 | 06:44 PM
PolishCowboyPL's Avatar
Default Raptor Help
Ok, first check if your parking brake is off.(you never know) second I don't think his filter would be soaked because if he raised the rear that would require the gas to flow uphill to get to the filter. Check that anyways. Maybe try messing around with the idle screw a little bit. Sometimes that helps me when the temp changes and stuff. Also check if your tank is filled. Other than that I really can't think of anything, run it with the fuel shut off until it runs dry, and open it and try then, maybe you have too much fuel somewhere and you just have to burn it up. I am no engine analysist but thats what I would do first, if it wouldnt work.
MIke.
Old Mar 3, 2005 | 06:58 PM
86LT250RFatty's Avatar
Default Raptor Help
Originally posted by: PolishCowboyPL
second I don't think his filter would be soaked because if he raised the rear that would require the gas to flow uphill to get to the filter. .
MIke.
he said he tiped it on his rear grab bar, which means the gas would flow onto his airfilter...he didnt stand it on his bumper lmao
[img]i/expressions/face-icon-small-shocked.gif[/img] i say check the air filter too.
Old Mar 3, 2005 | 07:18 PM
Bing's Avatar
Super Quad Patrol
Default Raptor Help
MIke.
last time i visited poland they were changing skidplates standing the quad on the front bumper.......lol
j/k[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Mar 3, 2005 | 07:21 PM
Bing's Avatar
Super Quad Patrol
Default Raptor Help
yep,,,could be the parking brake too
Old Mar 3, 2005 | 09:13 PM
Default Raptor Help
Last time I checked a raptor had a rear skid plate that you would take off easiest by lifting the rear up..
Why would you stand it up on the grab bar to change skids, its like 8 bolts straight under the frame.
WTF , no shi$ he didnt stand it up on his bumper..
I thought he ment he had it in the air on a hook or stand "resting" on the grab bar, as in holding it up by that....
MIke.
Old Mar 4, 2005 | 03:29 AM
Bing's Avatar
Super Quad Patrol
Default Raptor Help
MIke.
LOLOL
you must still have a stock skidplate!!
he stood the bike up,,,,like the original post states
Old Mar 4, 2005 | 04:54 PM
Default Raptor Help
Sure enough, Fuel in the air filter and compartment. Thx a lot for the info Bing, i don't know about the polish cowboy though.
Old Mar 4, 2005 | 05:49 PM
Bing's Avatar
Super Quad Patrol
Default Raptor Help
no worries
polish is a stand up guy[img]i/expressions/face-icon-small-smile.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
