when changing springs witch brings down top end
Old Mar 3, 2005 | 11:07 PM
swampbf750's Avatar
Default when changing springs witch brings down top end
when changing springs on the primary and the secondary clutch witch one brings down top end i was told secondary so i took my white spring out put stock in and the belt slips now i have a red epi in there now but i think i might put the white secondary back in and the pink primary back in this is on a bf i need help thanks
Old Mar 4, 2005 | 12:31 AM
kawiyowee's Avatar
You can probably stop the belt slip by reducing the shim(s) thickness behind the secondary spring.
Both springs bring top end down. The secondary stiffer spring is to lengthen belt life since it doesn't let the belt slip between the sheaves as easy as the stock spring, but loses high end due to friction losses.
The primary spring reaches any given speed at a higher rpm. The point of a stiffer primary is to get better acceleration when riding trails or short drags, not to increase or even maintain top end.
Divergent12
Dec 30, 2017 08:33 PM
merryman
Jan 19, 2016 04:29 AM
slowgsxr97
Sep 8, 2015 04:37 AM
Polarisman1123
Aug 13, 2015 08:13 AM
ghost civic
Jul 27, 2015 03:15 AM
