Is it true?
Old Mar 3, 2005 | 11:51 PM
Warrior02man's Avatar
Default Is it true?
Is there such thing as a UNI Pro Flow Kit.. or is it just the foam filter? Cuz.. my set up ahs a UnI filter with the rubber part that makes it so that it is attached (almost) to the air way. There is no Prefilter tho.. so i was just wondering if I ahve a Pro Flow Kit or just the UNI filter.. thx.
Old Mar 4, 2005 | 04:34 AM
maddog56's Avatar
Default Is it true?
Yes, you can buy pro-flow kits with either UNI or K&N air filters.
Old Mar 4, 2005 | 02:56 PM
enFORCER's Avatar
Default Is it true?
You have the kit.... The kit comes with an adapter plate.... Witch allows you to remove the stock air filter and replace it with the foam or k&N filter... Thats all the "kit" is.... When you buy it with the K&N you get an outerwear with it....
shimanok2
Jan 29, 2016 07:37 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
