New 450r
Old Mar 4, 2005 | 04:14 AM
iBhigh's Avatar
Default New 450r
Hey there everyone =)
New to the site, just wanted to say what's up and introduce myself... The name's Logan, and I live down in Southern Utah, in a little town you'd never want to visit. =) I've ridden quite a few utility quads, but I'm pretty much a newbie when it comes to sport quads. Last motorbike I owned was some 80's XR80 back when I was 13, and even though it ran like total junk, I still knew I wanted a dirk bike one day. A little while back my mind changed after I got hooked on quads after riding some old Honda utility's up at a cabin with all my friends. Ever since then my best friend has tried to convince me to buy a sport quad over a utility, and that he would buy one when I did. Well that day finally came, and I got my '05 TRX450r at the same time my best friend got his '05 Troy Lee Predator! =)
Here is a quick picture the night I brought it home, doesn't give it justice but atleast it shows it. Right now it's at my buddies shop because we were putting on nerf bars, but I did get to take it out for a few runs tonight... I'm stiff as a board, and even got pretty damn scared at times, but it's a blast! Should be able to ride this whole weekend so I can get a chance to get comfortable on it, any ideas on things I can do to help get comfortable? I am also curious as to what peoples opinions are about both the TRX and the Pred? My first 2 wheeler was a Honda, my first car was a Honda Civic, my work generator is a honda =p Point made, I decided to go with the TRX mainly for my good fortune with other honda products. I've heard all the opinions of my friends, but most are biased since they have never owned a different brand, or some have never even ridden a quad in their life. Would some of you mind posting some? I've watched the site for quite some time before I actually registered, and I enjoy the fact that mature conversations can actually happen on forum boards! Any comments, criticism, suggestions, ideas, etc.... are ALL welcome!
2005 TRX450R
I look forward to learning a lot from everyone, thanks! =)
Old Mar 4, 2005 | 04:23 AM
HellCat2020's Avatar
Default New 450r
Welcome to the site. I also am a strictly Honda guy but, have rode with everything and are all good in there own way.
Old Mar 4, 2005 | 09:44 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default New 450r
Welcome! What kind of terrain do you ride??? The 450 is a great bike for the open desert and fast more open trails. You will find however that on tight (slow) trails or anything even semi-thechnical, the high revving engine is going to require a lot of clutch work. If you do ride trails, a gearing change might be in order???
The TRX/CRF engines are high revving, and hard on their oil! Change you oil often! I never go more than 5 hours without an oil change on this machine. This is a great article, and everything that goes for the CRF also goes for your TRX http://www.thumperfaq.com/oil.htm Also, your engine and transmission oils are seperate (only the Honda 450R and CRF's do this......God bless Honda!) This is great because you can run a slick oil in the engine (JASO MB), and a transmission specific oil in the trans. My preferences are Maxima Ultra in the engine, and Honda HP Trans Oil in the trans.
I would break the machine in hard (http://www.mototuneusa.com/break_in_secrets.htm), and do an oil change (engine and transmission) after 1 hour, to get the metal shavings out. Do a valve adjustment at 10 hours (the dirt bikes have a reputation for being hard on their valves!). Later, when you want even more power, the engine hops up real nice (opened up air box, high flow air filter, cam, etc.).
And, don't expect those stock tires to last long riding rough terrain! I love Holeshot XC's for the desert. Nerfs and skid plates are a good idea too.
Enjoy!
Old Mar 4, 2005 | 10:55 AM
LTZ's Avatar
LTZ
Default New 450r
Welcome!! I second alot of what recon said and depending on where you ride if it's rocky invest in some high quality skid plates. I have the DG Bajas on both of mine and ride 90% of the time in the desert and they hold up great. Good luck with it and happy ridin................
Old Mar 4, 2005 | 11:27 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default New 450r
I think you will love the 450R. I know I love mine. If you do trail riding you should gear down to a 13 tooth front sproket, you won't have to do so much clutch work. I have ridden mine in the dunes, logging roads, trails and very technical trails. Once you learn the characteristics of this quad you will be able to ride it almost anywhere.
Now the Honda versus the Pred is very close. The Pred has a very smooth power delivery but hits the rev limiter quick and hard. It is a heavier machine and feels that way. The Honda will beat a stock Pred in a drag race. I like the reliability of the Honda as I've seen many people always working on their Preds. JMO
Old Mar 4, 2005 | 10:33 PM
iBhigh's Avatar
Default New 450r
Hey, thanks for all the great responses! It looks like I found the right place to get some real opinions, as well as lots of great advice =)
I don't really know which terrain I'm going to be riding mostly... Most of the riding areas around my town are deserts with sagebrush and hard red dirt, with simple ups and downs usually with pretty roughed up ruts and such since it's been raining off and on. Out of town there are lots of great mountain trail rides, not to mention I'm only about an hour away from the Grand Canyon so I'll probably be out there a lot! =)
Thanks for the break-in advice! I've only had the chance to ride her for about 30 mins the other night before the sun went down, but I plan on taking her out for about 4 or 5 hours tomarrow after work. Think I should change the oil tonight? I'm still pretty sketchy on the bike, since it's unlike anything I've ever experienced before so I probably won't be getting too crazy with it. My friend took me for a ride on the back and it gave me a better idea of how I need to shift my balance, so we'll see how I do once I get on her with some time to spare. When I first bought the bike almost all of my friends told me to just break it in how you plan to normally ride it so I think I'll follow your advice.
And thank you very much for the sprocket advice! I will probably be at the dunes a lot, but I also want a good bike that I don't have to be hauling *** on so that I can take it trail riding when I go hunting/fishing/camping/etc... and still be able to putt around just fine. None of my friends told me anything about the sprocket size making a difference so I'm very intrigued to hear more, any other advice? =)
Thank you again for everyones help! I put on some nerf bars last night, and I think I'll feel a little bit safer with them on =p I look forward to being a part of this great board, you all have already made me feel welcome. Cya =)
Old Mar 5, 2005 | 12:16 PM
Pirate Biker
Limping Rider!
Default New 450r
If your local Honda dealer doesn't have the 450R specific 13 tooth front sprocket just get the 13th tooth for the CRF450R. It will fit and work just the same.
Go for a ride with the stock gearing and then change to the 13 tooth and notice difference. You'll probably stay with the 13 tooth for the trails. It is really easy to change and you don't need to change your chain. You can adjust the slack out.
You can always change back for the desert and dunes.
I agree that dirt wheels assessment of this bike is off base. Many of the things they say about this bike, negative things, I find to not be the case.
Do some mods to this bike and it rips!
I have a 2 inch end cap in the muffler, rejet to a 180 main, 50 pilot and drop the clip on the needle to the bottom position, cut open the airbox lid and I put a Stage II Hotcam in it. I think that's all I'll ever have to do to it. It is now fast enough for me.
I'm an old guy (47) but I still like to go fast.
Old Mar 6, 2005 | 01:44 AM
iBhigh's Avatar
Default New 450r
I'll have to do that... I have to go and pick up some new gloves now anyway. =( I took her out today, and my friend explained to me the difference between my sprocket now and if I were to get a 13 tooth and I can definately see how a 13t could help in trail riding. I got to open her up a lot more than I did the other day, and I also got a chance to take her off some dinky jumps. It handles awesome, although I still feel a little sketchy about going up hills, anyone have any advice besides practically sitting on the tank?
I'm going to take her out tomarrow, so I suppose I'll wait until tomarrow night to change the oil like mentioned above. I also have to raise my shifter up a little bit to compensate for my boots, so hopefully she'll be a little bit easier to shift with my boots on.
Oh and just for future reference... Anyone that plans on going riding in Arizona make sure you stay off the trails! O.o Luckily the Arizona Rangers are a lot more chillax than the Utah Rangers I have encountered, so we just got warned but apparently you can't ride anywhere off the mains roads... Doesn't really make sense imo, since I think that was some funner riding as opposed to the Utah side, but I am all about being safe and respectful out there. Also, if anyone around the area of the AZ/UT border just outside of St. George wants some good stuff, I think you can actually take a main road all the way to some petroglyphs. Sorry if everyone and their dog has been there, today was my first time and it was a blast! =)
Thanks again for the advice, I'll be picking up a new sprocket asap!
Old Mar 7, 2005 | 02:50 PM
CyberSlacker2001's Avatar
Default New 450r
iBhigh,
One thing that I didn't see anyone mention that I think would be a big help for you since you are new to sport quads would be a shop manual. I bought one for my 450r for about $50 (I think you can find them cheaper) but, I must say it was the best $50 I've ever spent. I read that thing like a novel and it really has helped to give me an understadning on how that thing works!
Have fun!
Old Mar 10, 2005 | 02:33 AM
iBhigh's Avatar
Default New 450r
Thanks CyberSlacker, I'll check that out for sure!
Still haven't gotten that sprocket... bought a flag and shock covers instead! =p It's definately next on my list.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Asaran
Oct 8, 2015 11:14 AM
Aug 5, 2015 02:10 AM
dorene
Jun 5, 2015 05:25 PM
