Dial a jet owners I have a ?
Old Mar 4, 2005 | 10:01 AM
SPORTSMAN70003's Avatar
Default Dial a jet owners I have a ?
I'm thinking about ordering a dial a jet and had a ? or two. First of all you have to create a lean condition with the main jet like dropping it down a couple sizes right? Do you also have to create a lean condition in the mid range like raising the clip on the needle? Thanks for your help.
Old Mar 4, 2005 | 01:32 PM
Brambles's Avatar
Yes they do say you may have to play with the needle position a bit.
Old Mar 4, 2005 | 01:34 PM
Thanks my cilp on the needle is on the bottom notch so I have room to move it up. Thanks again
Old Mar 5, 2005 | 03:13 AM
Parkerman's Avatar
When you move the clip does up increes the fuel or down increce the fuel.
Old Mar 5, 2005 | 03:17 AM
Down increases the fuel.
Old Mar 5, 2005 | 11:34 AM
Backinthesaddleagain's Avatar
Hi SPORTSMAN70003
I have a complete Dial-a-jet kit that I have yet to install. I also got a TPI power valve. I've been waiting for some warmer weather to do the installation since I don't have a heated shop. If you have any questions relative to the instructions etc... just PM me and I'd be happy to pass on any detailed info from the instructions.
Bob
Old Mar 5, 2005 | 02:06 PM
Thanks Bob I sent you a pm.
Old Mar 7, 2005 | 01:27 AM
Parkerman's Avatar
I have heard you have to drill and tap your carb with this is it true?
Old Mar 7, 2005 | 09:31 AM
I don't think you have to drill in the carb only put a hole in the boot between the airbox and carb.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
