stripped cyl. where the head bolt screws into...
i recntly discovered that the cyl is stripped where one of my head studs screws into, it fits in there once i used a tap on it, but it is lose and doesnt torque to right specs...just spins in there...any advice on what ii can do to fix it or what someone else would have to do to fix it?????????????
Helicoils are quite easy to install, especially if you have a drill press. All you do is drill out the stripped threads, retap with the tap included with the kit, screw in the Helicoil, and break a small tab off the bottom of the Helicoil itself. The only trick is you must use the exact drill size listed in the instructions. It's really not that nerve-racking.
You can also use a "Time Sert". Not sure of the spelling. It is like a helicoil but it is one solid stainless piece. It won't come unwound like a helicoil can. Try asking a shop around you if they have them. They are fairly specialized so it my be difficult trying to find one.
Jeff
Jeff
I have used Helicoils in the past with no troubles at all....
Every once in a while I see one pull out or unwind. It seems to only happen with the bolts or studs that don't get removed on a regular basis.
If you have no experience with tapping or drilling the head...I would pay someone to do it for you.
Good luck
Good luck
SixSpeed5
8
Aug 2, 2015 05:38 PM
skeets44
Jul 17, 2015 01:04 PM
