1986 Moto4 won't start!! HELP!!
Old Mar 6, 2005 | 09:55 AM
xcrrrrrr's Avatar
Default 1986 Moto4 won't start!! HELP!!
My son has a 1986 YFM200 Yamaha Moto4 that starts 1st or 2nd pull with the recoil, but will not start with the electric start. The motor turns over just like it always has with the electric starter but it will just keep turning and will not fire. We pulled the plug and the spark is very weak when using the electric start, but if you pull it over with the recoil the spark is strong. HELP!!!!!!!!!!!!!!!!! I am so confused?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 6, 2005 | 10:35 AM
garrett5462's Avatar
the valves may have to be adjusted. my quad wouldnt start with the elcectric but it would with pull start or pop start it. check them.
Old Mar 6, 2005 | 01:37 PM
hondabuster's Avatar
Could also be a bad ground wire, not making good contact, or a weak battery. If the battery is marginal, the volts will drop far enough while cranking, that the spark gets weak. Monitor the voltage while cranking, or have the battery load tested.
jgreerberube
Jun 21, 2015 02:27 PM
bvolks
Jun 13, 2015 08:14 AM
TJM
Jun 11, 2015 01:28 PM
1000gade
May 27, 2015 12:37 PM
ragewraps
May 26, 2015 03:14 PM
