Breaking in my Rebuilt 400 engine
Old Mar 6, 2005 | 06:42 PM
DGScrambler400's Avatar
Default Breaking in my Rebuilt 400 engine
i am almost finished rebuilding my 400 engine, which i lost due to cold seizure [img]i/expressions/face-icon-small-disgusted.gif[/img] anyways, I had the case rewelded, and started from the bottom, replacing seals, some bearings, gaskets, piston, etc. How should I break this in. Wverybody I ask has a different method, and i dont know which one to believe. So, 400 owners, could you tell me how you broke in your 400s? Thanks alot
-DG
Old Mar 6, 2005 | 06:52 PM
1fastpolaris's Avatar
Make sure that you are jetted fat. Long warm ups. When you cant touch your cylinder head it is warmed up. In and out of the throttle all the time. Long cool downs. Hope that helps
Old Mar 6, 2005 | 07:03 PM
EAB's Avatar
EAB
Retorque the jug also, after cool down.
Old Mar 6, 2005 | 11:16 PM
Whitedog's Avatar
I put three hours on mine. 15-30 min at a time. Up and down on the throttle.
I also found that this was easier to do with the stock primary spring in it, That way you can get a wider range from low to higher rpms.
Old Mar 6, 2005 | 11:58 PM
duneaholic's Avatar
I second what everyone has said.
Old Mar 7, 2005 | 07:43 PM
Oh yeh..I would go thru at least one tank before going full throttle
Old Mar 9, 2005 | 04:48 AM
CamoKVF700's Avatar
Ride it like your gonna ride it! See link
http://www.mototuneusa.com/break_in_secrets.htm
Old Mar 9, 2005 | 07:20 AM
Bradracer18's Avatar
We always for the first tank of gas, took a paint can lid, and filled that little center cylinder(not the whole cap) full of oil, and dumped that in the gas tank.......just helps for a little more lube......
Old Mar 9, 2005 | 08:35 AM
RAJ's Avatar
RAJ
I also did something like that, I was mixing the oil and gas & and I still had the oil injector working.
Old Mar 9, 2005 | 09:45 AM
vmaxfrank's Avatar
If you premix and inject, just remember it will run a little leaner. More oil means less fuel and a higher air to fuel ratio. Shouldn't make much difference unless you are really jetted on the edge. When in doubt, richen it up a little.
