How do you change a belt?
Old Sep 23, 2000 | 10:36 PM
mudmagnum's Avatar
I was wondering if someone could tell me how hard it is to change a belt on a 500 Magnum.
Old Sep 23, 2000 | 11:06 PM
EasterEgg's Avatar
If it`s anything like a SC 500 , piece of cake. It may take 1hr tops. Unbolt the front fender from the floor board this makes it easier to get the cover out. I don`t know if this is correct procedure but I removed the center bolt for the rear pulley (don`t know correct term). Slipped off old belt, slipped on new, slid pulley back on shaft and torqued bolt. When re-installing cover use grease to hold the seal in, this will also help seal it. HTH
98 Scrambler 500
Old Sep 23, 2000 | 11:45 PM
Farmr123's Avatar
You shouldn't have to remove any bolts from either pulley. If you put the gearshift in Neutral, and (carefully) work the rear pulley open against the helix spring, you should be able to pry it open enough to be able to get the belt off over the front pulley. Put the new belt on the same way. Never did this with an EBS equipped machine, but I assume it is the same way. To avoid lawsuits (see thread marked "Here we go...") be sure to do this with the engine OFF. Otherwise advice is right on.
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
