sprocket size
hey i just put on 18-11-8 turf tamers on my 200x the low end and midrange are great with these tires i was wondering what sprocket size to put on to give it a little more top end without giving up to muck bottom and midrange thanks
Hey Paulie
When I run my 20's I use a front one tooth larger and a rear two teeth smaller with the stock number of links on the chain and my top end speed was about 4 mph faster than stock sprocket and tire sizes.
This is the only combination I have tried since I could have I chain while having 2 gearing choices.
You can't go more than 2 teeth in the front.
Jeff
Jeff
ok thanks can i run the stock front sprocket and just use a 38 tooth in the rear?? or is that point less? also every where i look there is only stock sprockets know of any place to get after market ones? also i bored out 20 over with new piston and rings and put on dg exhaust any other ideas for bolt on performance?? thanks paul
Here is a link to a 38 tooth rear sprockets for 83-85 Honda 200X
DENNIS KIRK
parts unlimited brand
With the 38 rear your sprocket ratio will change from the stock ratio of 3.33 to 3.17 which will give you more top end speed.
DO NOT FORGET YOU WILL 'PROBABLY' NEED A DIFFERENT NUMBER OF LINKS IN YOUR DRIVE CHAIN.
With the 13/38 combo I run I can use the same chain as when I run the stock 12/40 combo.
Jeff
DENNIS KIRK
Jeff
