250R Pipe/Silencer Seal
Old Sep 24, 2000 | 01:48 PM
Mike Frey's Avatar
I picked up an '86 250R a couple weeks ago, the pipe/silencer (full FMF system) seal is in rough shape. What should I use to seal it? I've been told by one person to use high-temp silicone and another to use some sort of clamp, like Cascade or TM Designworks. I'm sure either of these techniques will work, but I'm confused.
Old Sep 24, 2000 | 07:16 PM
ronhonda's Avatar
frey,
nice to see you are still around.
like you I also picked up a 89 250r. It needed some work, but it finally was done 2 weeks ago.
now I am saving up for new plastic and a ims gas tank(current plastic is beat to ****e) as far as seal goes, use both. better safe than sorry.
also have you purchased an exhaust for your 400?
I am in the process of getting a sparks system.
take care and good riding.
ron
ronhonda's Avatar
frey,
ron
Old Sep 24, 2000 | 07:19 PM
ronhonda's Avatar
frey,
ron
Old Sep 24, 2000 | 10:51 PM
Mike Frey's Avatar
I'm still here. Where'd you think I went!
No exhaust for my 400EX. It is staying the way it is for a long time. I bought the 250R for tinkering. I'll probably go with the TM Designworks o-ringed clamp.
I apologize for not posting pics of my R on my web site. I screwed up when scanning, and haven't made time to re-scan. Look for an update soon.
Old Sep 25, 2000 | 03:59 PM
trapperb1's Avatar
Where is it leaking exactly?
I would personally, pull the whole thing off, take the flange off the jug and put a new gasket on there, get a new split ring for the flange, then get some expansion chamber sealer. It's putty like, wrap some on the flange, shove the pipe on and wipe off the excess. It's really easy to work with. Then, get the rubber hose and "O" springs that go over the silencer and pipe connection. Put some chamber sealer on that connection also. That should seal up everything.
Old Sep 25, 2000 | 05:24 PM
Mike Frey's Avatar
It's not leaking. I unbolted the silencer and noticed that the silencer/pipe seal is shot. I was wondering if I should just have FMF send me a new seal (it's full FMF exhaust), or if I should buy an O-ringed alloy clamp. It is the pipe/silencer clamp, not the flange on the cylinder.
Where should I look for rubber hose? Hardware store?
Old Sep 25, 2000 | 08:24 PM
trapperb1's Avatar
Don't go to a hardware store, go to a Honda dealer. They have the section of hose and the springs. You may have to order them and wait a few days to get them. While you're there, pick up some chamber sealant. That oughta take care of it.
BTW, have you repacked your silencer? It's also easy and cheap to do and does help with performance and noise.
Old Sep 26, 2000 | 12:13 AM
Mike Frey's Avatar
I'm not sure we're talking about the same thing. I'm talking about the pipe/silencer seal, and my FMF system doesn't have any place for springs at the pipe/silencer joint. I plan on ordering the stock seal, which consists of a (rubber?) "silencer seal" and 2 "silencer seal bands" (o-rings?). I hope this works with an FMF system.
FMF owners, what are you using?
Haven't repacked yet. I bought some crappy packing from the dealer, and couldn't get it wrapped tightly. I'm ordering precut FMF repacking.
Old Sep 26, 2000 | 12:26 AM
trapperb1's Avatar
OK, we are talking the same thing. I have all FMF exhust on my 250R. It's the point where the silence slips over the pipe? I think that's right. Well, there is a rubber hose that fits that and two O-ring springs go with it. Pull the silencer off, put the hose onto the silencer with the O-ring springs, put the silencer back on, then shove the hose over the joint and roll the O-ring springs into place. Gosh, I hope that's it!
