Xplorer 400 making funny sounds
Old Mar 10, 2005 | 01:59 PM
BlackRaptor's Avatar
Default Xplorer 400 making funny sounds
This just started happening.
Then you are giving the quad gas it makes a rhythmic clunking sound. kinda loud. But only when you're on the gas. if i let off it stops.
It doesn't sound like it's something from the motor though.
One of my friends said his sled made this sound when the belt was going bad.
Any ideas?
Old Mar 10, 2005 | 02:38 PM
new2atv's Avatar
Mine does the same thing. I've yet to be able to tell where it's coming from. I'd like an answer as well.
Old Mar 10, 2005 | 03:36 PM
Hopefully someone will know.
Otherwwise i'm gong to rip into it this weekend.
I can't risk that thing breaking down on a trail in the middle of nowhere.
Old Mar 10, 2005 | 05:31 PM
duneaholic's Avatar
Sounds like you have a belt going bad. I've had this problem a few times as well. It's a real easy fix. Replace belt.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 10, 2005 | 06:25 PM
new2atv's Avatar
Would a Pure Polaris replacement belt be the best or is there another brand out there that would be better? My quad is a stock quad.
Old Mar 10, 2005 | 07:09 PM
conig's Avatar
my factory chain guarge has made this noise when it has gotten out of wack before, make sure it is tight. its easy to fix, if this doesn;t stop it follow the suggestions listed above.
Old Mar 10, 2005 | 07:34 PM
yamaharaptor350's Avatar
umm... could it be the piston slaping ive heard of that makin similar noises if thats the case get that thing fixed quick
Old Mar 10, 2005 | 08:10 PM
piston slapping normally has a little higher pitch tinging sound. this or more like a clunk. it sounds heavier then that.
Doesn't the chain normally make noise power on or power off because it's always spinning around.
Old Mar 10, 2005 | 10:41 PM
ftwflh's Avatar
DITTO
Old Mar 24, 2005 | 11:12 PM
new2atv's Avatar
Hey BlackRaptor, did you get this figured out? I changed the belt on mine and it's still doing it. I also tightened up my chain and chain guard. I still can't pinpoint where the noise is coming from. It kind of sounds like it's from the front drive shaft area. Do you think it could be something with the front drive shafts?
