RideorDie...Thanks
Old Sep 24, 2000 | 11:07 PM
stebob's Avatar
Hey Ride,
I haven't been around for a few days, sorry I haven't said thanks for all your info. and help until now. THANKS. You have really helped me a great deal. Sucks to be busy I haven't even put my parts on yet. I did however figure out what that slapping sound was that I thought was my chain. My stock exhaust pipe came loose. Tight as a button now and NO noise when landing off of big jumps.
I do have another lingering question for you about those wheel spacers though. I was curious if they actually took power away when you installed them. I remember you stating that you did not have enough power with the jet/k&n/pipe.
Oh yeah, something else, you where telling me how to do a wheelie by holding my shifter up and taching it then letting it down. This does not work for me, as soon as I shift up it goes into second and takes off while I'm still holding the shifter up. I'm suspecting I need to re-adjust my clutch release screw. Would you say the same?
Well, thanks again for all your input.
Stebob
Old Sep 25, 2000 | 07:02 AM
RideorDie's Avatar
Bob,
I feel that my bike demanded more power in the tight turns on the track with the spacers, but that is just my opinion.
The shifter on the Lakota is also a clutch. Lift up the lever but DO NOT CHANGE GEARS, it should clutch the motor almost 100%.
SAC UP RACING
99 Team Green Lakota
350 FST Stroked Big Bore, FST Cam, FST Valve Springs, FST Oil Cooler, running VP race fuel, CPE Race Porting, Modified Carb, K&N, Dyno-JET, Vented Airbox Lid(13 1" uni's) 4 Durablue Spacers, Renthal Bars, Motion Pro Kill, XCT Holeshots on Douglas,DG Exhaust & Head Pipe, Custom Seat cover, 14t Sprocket Specialties front and Sproket Specialties rear, RK Chain, and the list keeps going....
Old Sep 25, 2000 | 07:23 PM
rockerc's Avatar
totally (somewhat) unrelated, but my 220 i suspect has the same auto clutch shifter. will it hurt it to do what u described using the shifter as the clutch or what? any help is much appreciated...
Old Sep 26, 2000 | 06:19 AM
RideorDie's Avatar
RockErc,
The service manager said it should not hurt the bike, it may indeed cause the clutch to wear out a bit faster but will cause no major damage.
SAC UP RACING
