scrambler starter removal
Old Mar 15, 2005 | 10:51 PM
tmzg29's Avatar
Default scrambler starter removal
What is the trick to get a starter off of a 1999 scrambler 400. I removed the cable, and the 2 bolts that hold the starter to the mounting bracket on the clutch side. I loosened the long bolt that goes thru pull rope cover. I tried to remove the starter and it don't want to budge. I took a wooden handled hammer and tried to pry it away from the flywheel housing but it did not move. I don't want to force it because I don't want to crack the case. Any suggestions.
Old Mar 16, 2005 | 01:30 AM
oghma's Avatar
You actually have to remove the recoil starter and inside that case there are two bolts that hold the starter to the crankcase. Pull those two and the ones you have and it should come right off.
Old Mar 16, 2005 | 11:55 AM
conig's Avatar
ditto
Old Mar 16, 2005 | 11:14 PM
tmzg29's Avatar
Thanks Guys,
Starter is off and rebuilt.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
maxjung
Jul 13, 2015 05:11 PM
