Clutch cover bolt torquing spec's. - search results confusing?
Old Mar 16, 2005 | 12:29 AM
Lukester's Avatar
Default Clutch cover bolt tourquing spec's. - search results confusing?
I did a search on changing the primary spring. In this case it's an 04 Trail Boss - although it sounds like the instructions to R&R the spring are all the same for Polaris regardless of model. I read diff. tourque #'s and units of measure in the search results.
The 6 cover bolt tourque spec's. are 90 in. lbs. or ft. lbs.? The center bolt at 40 ft lb's? While I'm asking, do you use lock tight on any of these?
Thank you
Old Mar 16, 2005 | 09:27 AM
CED's Avatar
CED
Default Clutch cover bolt torquing spec's. - search results confusing?
That is in.lbs for the cover.I use the blue loctite for the center bolt only.The cover bolts have lock washers.Oh yeah the center bolt is ft.lbs.
ghost civic
Jan 15, 2020 07:43 AM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 15, 2015 10:48 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Unzzy66
Jul 11, 2015 10:01 PM
