Chain tightening
Old Sep 25, 2000 | 10:53 PM
FireBug's Avatar
I have a 1987 TRX 250X and i was trying to tighten the chain but the metal ring your supposed to turn won't budge, back or forth. Does anybody have the same problem? Post info on here
Old Sep 25, 2000 | 11:14 PM
JRM's Avatar
JRM
well, I have 100% zero experence with that quad, but i think some responce is better than none From a typical honda standpoint, there usally are one nut and one lock nut. Loosen the axle nuts and the lock nut, then turn in the inner nut unil you have a inch or two free play on the upper chain. then tighten up all nuts
Old Sep 26, 2000 | 12:33 AM
trapperb1's Avatar
If you have loosened the two allen-head bolts on the very back of the axle, loosen them quite a bit, then see if the axle will move. Don't use such a big pry-bar and too much leverage and break it. If that doesn't do it, something else is wrong inside the axle housing.
trapperb1's Avatar
Old Sep 26, 2000 | 03:58 AM
puddding's Avatar
the cam on the alloy bearing housing (gives you the adjustment, can wear down causing you to close the gap right up in the clamps....(where the allen keys nuts are).....this giving you no adjustment
this cam wearing maybe causing the alloy housing to hit on the inside (someone might of put a grease nipple on the housing?...(they don't come std)
ya never know
......the adjuster on the left side should move easily with a small screw driver
DON"T FORCE IT
FORCE=EXPENSIVE
you don't need to take a link out of the chain?.....your not right round on the adjuster
it should move......maybe you not holding your tongue in the right position?
Old Sep 27, 2000 | 12:36 AM
kickAZZ250xer's Avatar
I have a 250x. Try to loosen the chain. if it wont loosen either then there is something wrong. THe chain tightener might be all the way tightened. SO ull just have to alter ur chain. I recently had this problem. ANd have ordered a new chain.
talk to me on icq # 40464611
HOPE THIS HELPED
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
