DS 650 performance
Old Mar 23, 2005 | 12:28 AM
discopimp1975's Avatar
Default DS 650 performance
I ride an 03 Baja, and I just installed an Alba stage 2 exhaust kit. I am still waiting for a main jet so I can really try it out.... but what a sound it makes! I'm hoping to cook all my buddies who run Banshee's with Tommy T-6 pipes. Anyone running the same exhaust as me?? I want to know if I should run with or without my airbox lid, and what kind of jetting numbers your running. Ride on.
Old Mar 23, 2005 | 12:31 AM
03TRX300ex's Avatar
I've heard with the airbox gives more power
Old Mar 23, 2005 | 12:38 AM
....Next to go in is a set of cams, high comp piston, and an ignition box to change or eliminate the rev limiter... any suggestions people? I used to be a 2-stroke man so I dont know what to go with. I ride everywhere: dunes, trails, open roads, hillclimb..... so I think I should build mostly midrange into the engine. Whadaya think?
Old Mar 23, 2005 | 07:38 PM
DuneRider650's Avatar
I ride a little here and there......
well for the airbox there was a HUGE post i started about it back awhile...but it seems they make the best hp with the air box lid on with the stock carb...when i take mine off i for sure no i have more very bottom pull but loose some top end.
Old Mar 23, 2005 | 08:28 PM
MongoDS's Avatar
I run a Ron Woods CDI, it eliminates the rev limiter. There are times I wish I had a rev limit but most of the time it is not an issue. The more I ride the more accuanted I get with the shift points and there is no need for a rev limiter, other than a stuck wide open throttle (which has happened to me a couple of times I just kill the power no biggie) I personally see no need for one.
Then there is the Vortec CDI, I think a few guys on here are running it and love it. This particular CDI has different setting for different riding conditions, which is a very cool feature. The Vortec also has a rev lmiter and if I'm correct it changes with the different settings, again pretty cool.
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
