Works Triple Rate w/Rezz vs TCS Shocks
Old Sep 26, 2000 | 10:08 AM
jdsuareza's Avatar
Is worth the money pay $250 more for the TCS front shocks, versus a pair of Works Triple rate with rezz.
Somebody has used both?
Do you feel to much difference?
Thanks.
Old Sep 26, 2000 | 11:57 AM
nightlife7810's Avatar
I was wondering the same thing - the money saved would help pay for re-valving my rear shock. I hope some has ridden both and can give an honest answer!!
Old Sep 26, 2000 | 12:53 PM
jdsuareza's Avatar
Is somebody out there, that really can help us with this paradigm?
Thanks
Old Sep 26, 2000 | 02:24 PM
BUBBAG's Avatar
ALL I CAN SAY IS,,I LOVE MY AXIS! ! !
Old Sep 26, 2000 | 05:22 PM
SpeedDemn440's Avatar
i was asking that exact same question a while back. I now know that a 0-preload shock is the only way to go. TCS,Axis,Ohlins,ZPS are all zero-preloads as a triple rate works shock is not. What does this mean? Less speed out of the corners w/ works shocks and alot more likely to bottom out on that big jump. I say deifinately go with the TCS because if you don't you will end up selling those works shocks later. Theres a reason TCS cost more. Go to CTracing.com to check out setting up your rear stock shock to match a pair of front TCS shocks. Zero-preload all the way around. GoodLuck
Old Sep 26, 2000 | 07:00 PM
Skunky's Avatar
TCS also does a conversion to works if you already got them..
Old Sep 27, 2000 | 01:38 AM
rhino99's Avatar
I would get the triple rates without rezzys, or actually the dual rates, then when you get the money have TCS re-do them for ZPS and it will only cost like 20 more than just gettin TCS when you cant really afford them. If you have the money, get them instead, ZPS from what I hear and see are much better
Old Sep 27, 2000 | 04:12 PM
jdsuareza's Avatar
Thanks to everybody for all your comments, I decide to buy the TCS.
Skunky, I know that you will make a comment to help, you always do that. THANKS
Old Sep 27, 2000 | 06:03 PM
Skunky's Avatar
Well I appreciate that...
Old Sep 27, 2000 | 09:54 PM
LDJ's Avatar
LDJ
Works also sells a stadium shock that is Zero pre-load. You may want to try them.
hugemoth
Jul 20, 2020 03:28 AM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
bikedad3
Jul 2, 2015 02:15 AM
