Engine Knock
Old Mar 24, 2005 | 02:48 AM
Polaris500HO4x4's Avatar
Default Engine Knock
just changed my oil today and i ran my quad around and checked the oil a few times to make sure i wasnt low or overfilled... but i have noticed that my engine has been knocking louder, the normal polaris knock but its louder then usual.. is there something i should watch out for
Old Mar 24, 2005 | 04:36 AM
handycap's Avatar
Change to a heavy weight oil and see what happens!
Old Mar 24, 2005 | 10:19 AM
xcrider's Avatar
Keep your 0w40 oil in the machine. If you let it drain too long or pulled the screen you also needed to bleed / prime the oil pump. If you did that I would just ride it. It seems my 2004.5 500 is quieter than I remember my 2002 but then again I am probably just used to it.
Old Mar 27, 2005 | 05:46 PM
i get my oil in and out within 10 minutes.... i rode the crap otta it this weekend up in Hawkins and its running better and sounds smoother
thanks for the feedback guys!
Old Mar 27, 2005 | 10:05 PM
ftwflh's Avatar
Check th e primary clutch buttons when they get worn it sounds just like an engine knock.
Old Mar 28, 2005 | 01:10 AM
alright when i get the cover off what do i look for.. would i need a feeler gauge? im still on my original Dayco HP belt my quad has just over 1900 miles on it.
Old Mar 28, 2005 | 01:15 AM
fishing's Avatar
How do you bleed/prime the oil pump?
Old Mar 28, 2005 | 07:50 AM
ftwflh's Avatar
If the buttons are worn you will be able to tell.But you can eleminate other things by taking the primary clutch off and starting it if the noise quits it was your primary and you need to rebuild it if it is still there you have other problems.
Tomtom86
Aug 7, 2024 07:40 PM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
