2005 Winch Installed
I installed my new Warn Winch today, it went in without a problem. While I have it apart I added some protection to the throttle cable just in case. While I have it all apart is there anything else I should do or anything that needs to be moved or adjusted. I thought the only questionable issue was the throttle cable but if anyone has anything I'm game. Thanks Bart
Well, as I was putting the headlight pod together and I noticeda plug hanging. It is a white plastic plug with a green, brown and blu wire in it. I looked and can not see where it might go. Does anyone have any idea what this could go to or is it something extra????
On my 05 I noticed that the bolt that connects the shifter to the shifter linkage was rubbing on the removable side panel.
When I would put the shifter into the park position the end of bolt would catch on the panel and move it a 1/4 of a inch.
All I did was removes the bolt and inserted it from the other direction ( head of bolt now facing the outside of machine )
Make sure to add a small washer between the nut and shifter linkage.
