81' 185s Help
Old Mar 28, 2005 | 03:03 AM
SDATVER's Avatar
Default 81' 185s Help
I have an 81 185s that ran but smoked alot so i rebuilt the engine in it and also did a carb rebuild and new airfilter and everythin but now since i did all this i cannot get it started. The only way it will run is if u pull start it and it dies as sonn as you quit pulling and it runs really boggy. If you pull the plug out it looks like its brand new seems like its not getting gas so i cleaned the carb again that didnt work. Checked the valve timing and clearance again and it is good it also has good compression and good spark any ideas. Any help would be apprecciated.
Thanx
Old Mar 28, 2005 | 04:12 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
is the bowl filling with fuel?
Old Mar 28, 2005 | 12:18 PM
Lomax's Avatar
Also, do you have your firing time set right?? that was the problem on mine once i got it back together
superdizzyboi
ATC 3-Wheelers
Aug 30, 2015 07:22 PM
fourtraxmike
Apr 28, 2005 01:53 PM
robg
Mar 21, 2001 09:05 PM
63tbirdrick
ATC 3-Wheelers
Jan 22, 2001 07:50 PM
garyc660R
Oct 25, 2000 10:59 PM
