200x Clutch
Old Mar 29, 2005 | 01:03 AM
Jammerz's Avatar
Default 200x Clutch
Can someone please tell if the nut that holds the clutch on is regular or reverse thread. Or which way do you turn it while facing it. Also can you get it off without the special socket?
TIA
Old Mar 29, 2005 | 03:43 AM
ThrashAndCrash's Avatar
Default 200x Clutch
It is normal right handed threads. And the TOOL IS WELL WORTH THE $12. You can get it off without the tool but you will most likley kill the nut. Plus you need it if you torque the nut back on (most people aren't too pickey on that, but.....) The part# on mine is Mp 08-015 Not sure I've seen you before, so welcome to the forum, and keep throwing the 200X questions at us, there are a ton of good people on here.
Old Mar 29, 2005 | 03:50 AM
Jammerz's Avatar
Default 200x Clutch
Thanks, have been lurking around for a few months gathering info. Am rebuilding parts that need it and will probably have more questions as is progresses.
Old Mar 29, 2005 | 11:01 AM
paulie83's Avatar
Default 200x Clutch
hey i just did my clutch last week and the nut is def regular thread i made a socket with by cutting a regular socket down and leaving it with two teeth that fit the bolt worked perfect!!
Old Mar 29, 2005 | 08:33 PM
Jammerz's Avatar
Default 200x Clutch
Yes I thought I might try that. What size works the best?
Old Mar 30, 2005 | 06:28 PM
bigblock2stroke's Avatar
Default 200x Clutch
Dang, I paid $30 for mine (the motion pro vise grip one for taking off the flywheel too.
Old Mar 31, 2005 | 10:01 PM
haywoodjalikme's Avatar
Default 200x Clutch
I used a 3/4" impact 12 point socket and used an angle grinder to make the 4 teeth on it.
Note that the outside diameter of sockets vary from brand to brand slightly and an impact socket side walls will be thicker than a standard socket. I decided on the impact socket because I thoght it would be stronger.
Good luck
Jeff
Old Mar 31, 2005 | 10:04 PM
MongoDS's Avatar
Default 200x Clutch
Last weekend I changed the clutch on a 86 200x and once the cover was removed there were two large nuts to remove. The nut on the clutch basket was right hand but, the nut holding the oil filter( i guess that is what it is, its a centrifical force filter right? anyway) was reverse thread. I guess the 86 is totally different from 85 and older.
Old Apr 13, 2005 | 07:15 PM
Jammerz's Avatar
Default 200x Clutch
Okay guys, I made myself a tool and got everything apart no problem. The steel discs don't appear to have any heat marks on them and appear to be unwarped. A parts guy told me you have to measure the thickness of them to tell if they need replaced, is this true, and what are the specs? Or do you just replace the fibre discs?
TIA
Old Apr 14, 2005 | 09:36 PM
paulie83's Avatar
Default 200x Clutch
i just did mine and my steels looked fine so i just replaced the friction plates and it works great!!
