compression and valve adjustment???
Old Mar 29, 2005 | 03:03 AM
grizz9988r's Avatar
Default compression and valve adjustment???
I posted a week ago and I had some chattering noise comming from the top end of my ds. I was told that is could be a cam chain adjuster. I pulled the old one out and thought it was bad so I ordered a ron wood manual adjusting one. I just got it and put it in and still have the noise. If the valves are out of adjustment will they make noise? I checked my compression and it reads about 125 psi with throttle wide open and not doing any thing with the decompression lever. Does this seem about right? Plugs look alittle white on the end piece. Just trying to find out where this noise is comming from.
thanks
Old Mar 29, 2005 | 10:05 AM
Oldmanracing's Avatar
http://www.ljsoftware.com/DS/Valves.htm
Valves have a tendency to get tighter when motor is new.
Whenever the valve train seems noisy, check valve clearance.
A fello DS rider created this site. Great help to us all.
Old Mar 29, 2005 | 12:40 PM
jackass650's Avatar
well here is my .02 cents I read somewhere not doing anything with the decompression lever and checking compression you should still get over 180 lbs psi and with the lever deactivated you should be around 220 psi, When I checked mine last fall I got 185 with the lever deactivated and when I pulled my motor down my ring endgap was 1.3mm and my intake valves were not seating, as a matter of fact I just got it back together yesterday and fired it up awesome totally different machine,
Old Mar 29, 2005 | 01:04 PM
Majorecho's Avatar
my experiance is with WOT only I 've seen 150-160psi on a healthy motor @ 5000ft. With the decomp lever also disengaged the compression goes up to 185-200 on a stock motor. At lower elevations it should be higher in each instance.
donintennessee
Jan 8, 2021 12:40 PM
Divergent12
Dec 30, 2017 08:33 PM
ghost civic
Jul 19, 2015 10:13 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
