Lectron - needle access?
Old Mar 29, 2005 | 01:46 PM
DSengineer's Avatar
Has been here a long time!
Default Lectron - needle access?
For you guys running Lectron's have you found an easy way to access the single screw on the slide cover closest to the gas tank. It currently sits directly under the gas tank cover and I don't want to have to remove it every time I make an adjustment. I was thinking of cutting about a 3" half circle in the bottom of the gas tank cover directly over the carb.
Old Mar 29, 2005 | 02:04 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
I have never had that problem with the clearance. I have noticed on onther bikes that you have to take off the cover.
If I were you I would cut a hole on the tank cover if it isnt noticable.. I might have a longer boot from intake to carb that gives me enough clearance.
Old Mar 29, 2005 | 02:16 PM
LuvTheBomb's Avatar
I replaced the screws with button head allens, and just use a ball end allen wrench to get it off.
Old Mar 29, 2005 | 02:25 PM
fast69's Avatar
I cut it and the seat covers it.
Old Mar 29, 2005 | 06:40 PM
MongoDS's Avatar
Yep, I just notched the plastic, and think of all the weight your shaving [img]i/expressions/face-icon-small-confused.gif[/img] lol. It also allows the cable to stick up vertical for an easier pull.
Old Mar 29, 2005 | 08:40 PM
5X's Avatar
5X
I just loosen the carb up a bit and twist it counter clockwise.
Old Mar 29, 2005 | 11:47 PM
busmechanic's Avatar
this is was I did as well. loosen the boot screws.
Old Mar 30, 2005 | 01:47 AM
BlackHawk's Avatar
I guess you guys are kinda lucky in having the stock tank, there will be no notching or cutting of the IMS tank for that type of access, you would be putting a hole right into the tank to do that. Oh well, I like having 5 gallons of gas though!
Old Mar 30, 2005 | 07:30 PM
222's Avatar
222
simple for me. I just don't put the third screw in. But then again, I only run half the nuts and bolts that came stock on my DS anyway (weight savings you know!).
222
Old Mar 30, 2005 | 09:43 PM
5X's Avatar
5X
Hey 222 how much weight did you save by removing half the bolts? What's your ds weigh now wet?
