Changing CV boots?
Old Mar 29, 2005 | 09:57 PM
Razr24's Avatar
Default Changing CV boots?
What tools do I need to change the CV boots? My friend has a Rincon and is having problems. any help or info would be helpful.
Thankx...[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 30, 2005 | 01:37 AM
Gimpster's Avatar
I could go into detail if you specify front or rear CV boots. It takes different tools to remove front and rear knuckle mounting bolts.
Other than that, a Snap ring plier, and a small screwdriver to disassemble the axle. I can tell you a trick, when reinstalling the axles. Make sure the C-clip openings on the end of the axle splines is facing up, when you slip the axles into the diffy. ( keeps the ends seated in the groove, and they will click in easily when the axle is tapped on the end to install them.
----- Gimpster -----
Old Mar 30, 2005 | 07:33 PM
Razr24's Avatar
Thankx for the trick. Gimpster. I found out on Honda's you don't need a crimping tool. You just need to hammer the C-clip over and pound it down.
Old Mar 30, 2005 | 09:28 PM
Gimpster's Avatar
Yep, the bands are reusable if a person is carefull taking them apart.
----- Gimp -----
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
bigbear350quad
Sep 11, 2015 12:40 PM
cornermike
Sep 10, 2015 08:30 AM
DM2015
Sep 7, 2015 10:36 AM
