400 EX Headbolt torque
Old Mar 31, 2005 | 06:47 PM
Redbaron's Avatar
Default 400 EX Headbolt torque
Would someone please tell me the correct torque for the head bolts when re-assembling a 400 EX. I'm assuming all 4 bolts are the same.
Old Mar 31, 2005 | 07:28 PM
Fl45h's Avatar
Which bolt are you refering to I would be more than happy to look it up.
Old Mar 31, 2005 | 09:20 PM
Gimpster's Avatar
The cylinder head nuts ( acorn headed ) are torqued to 33 foot pounds
----- Gimpster-----
Old Mar 31, 2005 | 09:36 PM
Fl45h's Avatar
The 4 nuts are listed at 44N.m 4.5kgf.m and 32lbf.ft the 13 bolts (8mm) are listed as 22n.m 2.2kgf.m 16lbf.ft also take note the specs are for a '05
if you want I can scan the page.
Old Mar 31, 2005 | 09:43 PM
Gimpster's Avatar
Only one of those bolts on the cylinder head cover is a 8mm bolt, The other 12 are 6mm bolts.
Your specs are not the same as listed in my Honda service manual
----- Gimpster -----
Old Mar 31, 2005 | 09:53 PM
Fl45h's Avatar
oops! you are correct the 6mm bolts are not listed in my manual under that section. Under standard touque values it states 6mm nuts and bolts have a value of 22N.m 1.0kfg.m 7lbf.ft I hope this helps.
Old Mar 31, 2005 | 09:54 PM
Fl45h's Avatar
It also states to tighten those bolts in a crisscross pattern
Old Mar 31, 2005 | 10:21 PM
Redbaron's Avatar
Many thanks to those who replied. This gives me all the information I need.
Old Mar 31, 2005 | 10:50 PM
Fl45h's Avatar
I am glad to help out a fellow rider [img]i/expressions/face-icon-small-smile.gif[/img] If you want I can get you a link to where you can buy the shop manual, for around $40 US
Old Mar 31, 2005 | 11:17 PM
HondaMan440ex's Avatar
I don't know if this is to late. but the 8mm bolt is torqued to 17 ftlbs. and the rest of the bolst are only 88 INCH ILBS. i know this for a fact because i had to Heli coli all my bolts becaue i over torqued them.. if you need anymore help let me know. i just put mine back together.
