fuel
Old Apr 4, 2005 | 08:57 AM
mountainclimber's Avatar
Default fuel
Can I use a higher octane fuel in my 400 4x4? I use 87 now.
Old Apr 4, 2005 | 10:02 AM
ethernut's Avatar
Default fuel
You most certainly can, but it's not likely to give you much benefit. I had a 375/400 cat that would seem to ping a little more when I used 87, 89 seemed to cure it. But as far as power is concerned you probably won't notice anything different.
Old Apr 4, 2005 | 12:25 PM
WhoDatInDaMud's Avatar
Default fuel
Higher Octane does nothing for lower compression engines. There is no power increase but it does burn hotter. Octane is to stop pre-detenation which can cause problems and damage to a high compression engine.
Always stick to the fuel and recommended lubricants as specified by the manufacturer.
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
