400ex Brake Shim?
Old Apr 5, 2005 | 10:22 AM
robbls's Avatar
Default 400ex Brake Shim?
Did you reuse the shim that comes in the rear brake caliper on your 400ex or similar machine?
I just installed new pads and I think I am going to try to run it without the shim and see if it wears any faster or slower.
Old Apr 5, 2005 | 02:52 PM
wheelinguy2003's Avatar
i reinstall if available....it came off it...so i put it back on....would be interesting to know how it will wear... hey why dont you install one and give us an update if there is a difference...just a thought
Old Apr 5, 2005 | 10:39 PM
400exrider123's Avatar
hey i noticed u have a PRM Grab Bar i was wondering how u did that since the grab bar is kinda attached to the sub frame....just wondering because i would like to swtich that up!
Old Apr 6, 2005 | 09:26 AM
robbls's Avatar
PRM sells tabs you can weld on to your subframe, so you can cut the old grab bar off and attach a new one.
They also sell a grab bar that is designed to bolt over the existing grab bar if you want to avoid the welding and cutting.
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
