gas mileage
Old Apr 5, 2005 | 06:56 PM
eton150's Avatar
Default gas mileage
my buddy is haveing trouble with gas mileage on his i think 03 700sportsman it does not have efi he said he is only getting 9 miles per gallon he did say it is running fine also he said if he goes up a incline gas leaks out the i guess over flow tube does anyone have any idea's thanks for your time.
Old Apr 6, 2005 | 01:04 AM
swampman's Avatar
Default gas mileage
well I bet you he even losses gas while hes cruising down the road, I think we had a similar problem on are sportsman 500 because I think some kind of float or something was stuck open. if it comes out of the overflow tube from the carb. it usually means somethings stuck open
Old Apr 7, 2005 | 10:38 AM
tiptoebox's Avatar
Default gas mileage
i have a new 05 sportsman 600 and i get the worst gas milage i have ever seen, i was horsing around for a half hour and i spent over a half a tank of gas, that is crazy, im very disapoint in gas milage for it,
Old Apr 7, 2005 | 01:10 PM
SPORTSMAN70003's Avatar
Default gas mileage
My 03 700 gets about 35 to 45 miles before I have to turn the reserve on. But I guess the bigger carb and other mods didn't help [img]i/expressions/face-icon-small-happy.gif[/img].
Old Apr 7, 2005 | 01:16 PM
tiptoebox's Avatar
Default gas mileage
thats insane, i dont think mine is that bad, but it should be better, I dont have reserve, so i am kinda scared to go to far by my self till i find out how far it will go when the gauge says empty, maybe its my gauge too, i will give it an honest trail run next week, but it doesnt take long to burn a half a tank trying to ride wheelies and jump driveways....
my 400 04 sportsman got 90 miles before i put it on reserve and it went almost as fast as my new 600, just wasnt half as powerfull, i should have just put a clutch kit in it...
Old Apr 7, 2005 | 01:35 PM
NLWarrior01's Avatar
Default gas mileage
I get about 100km per tank HARD riding (flat out, hard accellerating, etc) on my Warrior, or 160+ km of easy trail riding. My tank is 9 litres or just a bit more than 2gal.
Old Apr 7, 2005 | 02:38 PM
swampman's Avatar
Default gas mileage
yea it may only get 15 to the gallon but their isn't a reason for it leaking out the tube from the carb.
Old Apr 7, 2005 | 08:01 PM
eton150's Avatar
Default gas mileage
swampman is this check valve your talking about located outside or inside the gas tank.
Old Apr 8, 2005 | 11:11 PM
swampman's Avatar
Default gas mileage
the float or valve should be inside the carb. all the gas tank does is hold the fuel until its pumped into the carb. and from their its regulated by the adjustment on the carb, but if it leaks out of the tube from the carb. then something is probably sticking inside of carb. causing it to flush out the extra gas through the tube
Old Apr 9, 2005 | 02:43 AM
MarkSD's Avatar
Default gas mileage
What gas mileage should ATVs get? A friend of Mine has the new Kaw Brute Force 750. Get said he gets 120 miles on a tank. He said that the gas guage on his goes down to the Empty and then you can still go 40 miles or so. Do the Polaris ones get real bad mileage? I am not sure what size tank is on his ATV either.
