which carb/intake???
Old Apr 9, 2005 | 10:28 PM
Knowpig's Avatar
Default which carb/intake???
For a E-ton Viper 90 with pipe, air filter, and clutch mods-
What is the best carb choice when using the 54mm big bore kit????????
And will I need a different intake to use it??????????
Old Apr 9, 2005 | 11:00 PM
HQR109's Avatar
is the 54 stock or ported ? using the stock 42mm crank or the 47mm stroker crank ? most the 54 cylinders are for the 47 crank so if the cylinder was not decked you will have low compression. if the cylinder is not ported a 20mm carb with a koso or oko intake will be fine,
Mark
Old Apr 10, 2005 | 02:27 AM
Knowpig's Avatar
I am looking to get a stock 54mm big bore kit. And I run a stock 42mm crank. Is this a bad idea/combination???
How low will the compression be???
Old Apr 10, 2005 | 08:15 PM
HQR109's Avatar
get a 53mm cylinder. the 54mm is for the 47 stroker crank. you will have to mill your 54 cylinder to get a decent compression number.
Mark
Old Apr 11, 2005 | 07:51 PM
Knowpig's Avatar
LOL!
This got way off topic!!!!!!!!!
I looked into this a little deeper-the kit I am looking at is designed for the stock stroke 90's. They claim 180psi cranking compression with the stock 42mm crank. I have my trusty snap-on compression gauge set, maybe we'll put it to the test.
Old Apr 11, 2005 | 07:57 PM
HQR109's Avatar
ok just remember i told you so. stock stroke 90's ? some are 42mm stock and some are 45mm. is this kit an ebay item ??
Mark
Old Apr 13, 2005 | 12:48 AM
Knowpig's Avatar
Mark-I sent you a p/m.
Old Apr 14, 2005 | 09:39 AM
Rusroc's Avatar
I am having much trouble from my stock carb. Where can I find a good replacement?
Old Apr 14, 2005 | 10:20 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
WRH RACING
Old Apr 17, 2005 | 12:28 PM
wrh16's Avatar
Remember Mark told you so.
Anybody can deck the cylinder, but the ports will not be in the correct place. A correct 52 or 53 will make more power, every where!
Samson you ready for more pie-err Yet? That's how Mark says it.
