which carb/intake???
For a E-ton Viper 90 with pipe, air filter, and clutch mods-
What is the best carb choice when using the 54mm big bore kit????????
And will I need a different intake to use it??????????
is the 54 stock or ported ? using the stock 42mm crank or the 47mm stroker crank ? most the 54 cylinders are for the 47 crank so if the cylinder was not decked you will have low compression. if the cylinder is not ported a 20mm carb with a koso or oko intake will be fine,
Mark
Mark
LOL!
This got way off topic!!!!!!!!!
I looked into this a little deeper-the kit I am looking at is designed for the stock stroke 90's. They claim 180psi cranking compression with the stock 42mm crank. I have my trusty snap-on compression gauge set, maybe we'll put it to the test.
Remember Mark told you so.
Anybody can deck the cylinder, but the ports will not be in the correct place. A correct 52 or 53 will make more power, every where!
Samson you ready for more pie-err Yet? That's how Mark says it.
