misfire at idle, backfiring while under load, and stalling
Old Apr 10, 2005 | 01:56 AM
brianteel's Avatar
Default misfire at idle, backfiring while under load, and stalling
This just started happening. Once it warms up it will not icle right and it misfires and backfires then stalls. It does it at idle and while riding. We cleaned the carb and replace the plug. I do run 105 low lead all the time but have been doing it for 6 monthes now with no trouble.
I have:
Aluminum Air Box
K&N
jet kit
Exhaust - Pro Circuit
Old Apr 10, 2005 | 09:13 PM
LittleBill's Avatar
that really high octane there a particular reason u feel the need to run 105 octane, my buddy runs 89 in his with the same mods
Old Apr 10, 2005 | 09:20 PM
brianteel's Avatar
it is free
Old Apr 11, 2005 | 12:31 AM
hondabuster's Avatar
Did the problems start after the rejetting?
It idles better when cold, than warm? Good chance the idle circuit is too rich.
Is it a stock size pilot jet? How many turns out is the mixture screw?
When it starts to run crappy...if you pull the choke on...does it get better, or get worse? You can do this at partial throttle as well, if thats where it runs crappy.
If it gets better...the jetting is lean. If it gets worse..the jetting is rich.
Old Apr 11, 2005 | 01:05 AM
YBlasterboy's Avatar
Is it full on gas?
Old Apr 11, 2005 | 07:45 AM
brianteel's Avatar
The problem just started....i had it running for about 8 monthes with no problems at all.
it is fine when it is cold i can ride it for about 5 minutes then it starts running bad.
i am not sure of the sizing on the jets but like i said it was running perfect since i got about a year ago now then it just started last week.
it runs bad threw the whole range of the throttle and the choke does not do anything to help the problem. if anything it just stalls when i turn it on i cant keep it running even giving it gas.
I really dont think the jetting is the problem because it was running fine and just started. I pulled the carb completely apart cleaned and put everything back the way it was. I had something similar to this and it was when the intake pipe fell off the carb.
yes it has enough gas
Old Apr 11, 2005 | 02:16 PM
It almost has to be a carb or fuel related problem. If it was electrical, it would act up cold too.
Make sure the tank vent and the carb vent are open, and not restricted. When it stalls, does it restart ok? does it then run for a bit before acting up? Check to be sure the intake tube is tight and leak free.
Old Apr 11, 2005 | 11:56 PM
brianteel's Avatar
where is the carb vent? when it starts it will kind of start but choke out after about a minute....idling it is ok but does stall as soon as you give it gas then it gets really bed
Old Apr 12, 2005 | 04:26 PM
Look at picture 6 in my gallery. The brass tube which sticks up in the float bowl is the vent, its connected to the rubber hose at the bottom of the float bowl. Sometimes that rubber hose gets blocked by dirt or mud, and then the float bowl wont vent.
When it restarts...is there black or dark smoke in the exhaust?
If you run with the lid off the air box, will it run better, when its warm? If you go far a short ride with the lid off, will it still stall?
If that isnt the problem, then I think youre gonna have to pull the carb and look it over good again. Are the jets loose? How many turns out is the mixture screw?
Old Apr 12, 2005 | 07:12 PM
brianteel's Avatar
i will check for that tube i am not sure we had the thing apart 3 times and mades sure everything was clean....i cant ride it at all. I will start it let it warm up for a second then it will start doing it
COFatboy
May 2, 2020 12:06 AM
donintennessee
Aug 19, 2015 02:22 PM
cdoren
Aug 16, 2015 11:22 PM
momma's bike
Aug 6, 2015 09:49 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
