Rubicon oil change ?
Old Apr 10, 2005 | 04:13 PM
Bruce403's Avatar
Default Rubicon oil change ?
Changed the oil on my Rubicon for the first time. The manual states that you should refill with 5.2 quarts. Mine wouldn't even hold 4 quarts before it was over flowing? Is the manual correct or have I done something wrong? Thanks for any help!
Old Apr 10, 2005 | 05:22 PM
oledan's Avatar
The manual is correct. I have to start my motor briefly after putting in about 4qts to let the oil circulate then i put in the remaining oil. I may have had to start it twice but after it was all done the oil was right where it should have been after 5.5qts.
Old Apr 10, 2005 | 09:42 PM
Bruce403's Avatar
I tried letting the motor idle for 5 minutes as the manual recommends. Then I re-checked the oil level and there was no room for more oil. If I were to add more oil it would just spill out of the oil tank. Has anyone else experienced this on their Rubicon? Thanks for any help or input!
Old Apr 10, 2005 | 11:42 PM
Specta's Avatar
Did you remove both drain plugs and change the filter??
Old Apr 11, 2005 | 04:10 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
First off, to much oil creates a lot of extra pressure where you don't want it, so be real carefull. You can end up with blown seals, oil lines, or other damage.
I have no personal experience with the Rubicon, but it sounds like you have to drain BOTH the engine and transmission??? If you just drained the engine, you could have left behind lots of oil in the trans that you aren't accounting for. Just a guess based on Spectra's comments???
Both my 400's are "dry sump" engines, that have an external oil tank. You have to drain BOTH the tank AND the cranckase. You refill the tank first with as much as it will hold, start the engine BRIEFLY to distribute the oil to the cranckase, oil coolers, and oil filter, then shut it off and top it up again to the proper level. Sounds like you have a similar situation.
Old Apr 14, 2005 | 04:15 PM
Fantasea's Avatar
This is for "Specta" Pro Rider, You list you have a 2001 Rubicon. Have you had any issues with it? I am considering a used 2001 and wanted your opinon. Is there anthing I should be careful of? The machine has 1052 miles on it.
Thanks for your help
Fantasea
Old Apr 14, 2005 | 04:52 PM
MikeM's Avatar
both of my drain plugs are on the engine
Old Apr 14, 2005 | 06:53 PM
Specta's Avatar
We bought it in April 2001 so we are starting our 4th summer. We have 5075 miles and 600 hours. So far I have spent $12 for left upper control arm bushings and shaft. It runs every bit as good as it did when it was brand new. Do the maint, use quality oil and Honda filters.
Old Apr 14, 2005 | 08:50 PM
Fantasea's Avatar
Thanks for the info. I do appreciate it. I will give the guy a call and see if he is ready to part with it.
Fatasea
Old Jun 11, 2005 | 09:48 PM
RedGoblin's Avatar
How do you reset the LCD after you've changed it so that it doesn't say "oil change?"
ReconBayou
Oct 31, 2022 05:37 PM
shimanok2
Jan 29, 2016 07:37 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
