03 eton master cylinder problem
Old Apr 10, 2005 | 11:17 PM
kkapp's Avatar
Default 03 eton master cylinder problem
I have an 03 eton 90 and the master cylinder has quit pumping any fluid. I have pulled it apart and replaced the oring, the plunger looked good. It still does not work. Has anyone else had an issue of this nature?
Old Apr 17, 2005 | 01:17 PM
wrh16's Avatar
No.
Old Dec 4, 2005 | 08:38 PM
Makki's Avatar
you mean piston or oil pump
if is piston replace piston rings
if is oil pump you sometimes must put oil into pump and hoses
because you have free air inside so pump cannot work.
Old Dec 5, 2005 | 07:07 PM
Makki's Avatar
Sorry I am from Croatia (bad tehnical engl.)did you mean brake cilinder??
Ramman1
Jun 16, 2016 09:07 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Jul 7, 2015 11:00 PM
MNatv89
Jul 7, 2015 11:36 AM
