SP 800 stock wheels
Old Apr 12, 2005 | 12:44 PM
wyobulls's Avatar
Default SP 800 stock wheels
I just bought the mossy oak sp 800efi and want to put itp 589 ms on the stock wheels. Will a 26x9 and 26x12 fit without rubbbing with the stock or do you need the itp wheels? I don't really want to go with a shiny wheel on the mossy oak color so I thought I would stay with the black wheels that comes with it.
Old Apr 12, 2005 | 03:17 PM
Oleman's Avatar
I don't have your answer, but check your front tire and see how much clearance you have between the tire and spindle. You can figure you'll need at least 1/2" clearance for 9" at the cross section. Same for the rear but you'll need 1" clearance. The problem with going to a wheel with more offset is it pushes the tire outboard and will likely throw mud past the fenders. ITP does make a black powder coated rim in their type C-4. Your stock wheels are 12x6 and 12x8 in the rear . A 12" rear tire will fit better on an 8" rim than a 7".
Old Apr 13, 2005 | 12:52 AM
arkrider's Avatar
You can try to mount the tires on the stock rims. Then after you get them on if you think you need more space try Highlifter's 1" Spacers or look at ITP's C-Series Type 4 black rims.
Chad
Old Apr 13, 2005 | 07:06 AM
GE4x4's Avatar
you will be fine on the 9" fronts.
Old Apr 13, 2005 | 10:53 AM
2c3's Avatar
2c3
it come stock with 26s so the mudlite 26 should work fine as long as you dont go over 9in wide
Old Apr 13, 2005 | 12:40 PM
wyobulls's Avatar
Hey, everyone, Thanks for the info! I got my dealer putting the ms 589 on the stock wheels right now so I will find out soon if there will be any problems! Thanks again!
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
XxS0ccerstarxX
Aug 27, 2015 02:31 PM
Cantbuytime
Aug 17, 2015 06:33 PM
metal249
Jul 28, 2015 09:35 AM
