New motor wont start...HELP!!!
Old Apr 12, 2005 | 07:59 PM
89gt50's Avatar
Default New motor wont start...HELP!!!
I tore the motor down about 6 months ago and finally got it back together. This is my 300cc bayou.. I only took apart the top end, put new valves, piston, rings, and gaskets in. At first I tried to start it , but no luck. After lots of time spent trying we realized the valves werent adjusted right and it wasnt getting enough compression. I checked spark, and its there, and now compression is too. The timing at the crank is right on the mark, as is the cam sprocket. We tryed spraying carb cleaner at first, then hooked up the gas tank. I have no idea what to do....please help.
Old Apr 12, 2005 | 09:43 PM
holeshotz8436's Avatar
a callled cwr rebuilt my lakota engina which is basically the same thing as the bayou, the owner greg is very knoladgable if you call or email him he should be able to tell you whats wrong and how to fix it or at least lead you in the right direction about the problem. His email is greg@cycleworksrscing.net and the website is cycleworksracing.net and the phone is 717 637 1907
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
