250R pipes
Old Apr 14, 2005 | 11:44 AM
JkAss's Avatar
Default 250R pipes
OK people. I need some input. I have a 85 250R and need a new pipe. What pipes are you running on your 250R's and why? I know Paul Turner makes a good one as well as ESR, but would like to get some feedback about them or others.
Thanks
Old Apr 15, 2005 | 11:48 PM
atc250ratic's Avatar
Default 250R pipes
Oh right on kewl topic I am glad you stared it. Hopefully this one really takes off.
Old Apr 16, 2005 | 02:25 AM
okieRrider's Avatar
Default 250R pipes
I am running a Paul Turner midrange pipe on my 85 and it works excellent but falls out when i shift from 5th-6th gear.....I ride mostly tight trails anyways so the mid range for me works great....Chris
Old Apr 16, 2005 | 03:22 AM
JkAss's Avatar
Default 250R pipes
I only ride in the dunes so I need something more on the top end side. I'm always on it. The quickest way to get from one place to another is FULL THROTTLE!
Old Apr 17, 2005 | 10:57 PM
markdb420's Avatar
Default 250R pipes
I have a Paul turner Hi-Rev pipe, and it rips mid to top end! It is good on the bottom end, but from half to Wide open throttle its pure and true! If your going to be in the dunes then I would recommend the Hi Rev pipe from Paul Turner!
Old Apr 18, 2005 | 11:43 PM
shocker's Avatar
Default 250R pipes
Have no complaints about my FMF fatty. I have had a DG and a Paul Turner and don't feel either one of those compares to the FMF. Nice gains through all ranges.
Old Apr 19, 2005 | 09:14 PM
Default 250R pipes
I am not sure what type of pipe I have. It has no markings and was on the trike when I bought it. Can anyone tell me what it might be. Pics are in profile.
Old Apr 19, 2005 | 10:05 PM
markdb420's Avatar
Default 250R pipes
I have FMF fatty pipe, on my 86 and it was on my big bore 85 and it sucked! I went with Paul Turner Hi Rev and it is awesome on my big bore. It woke the bike up and has helped me get better starts and really pulls thru the mid range and on top its smokes almost all the pipes and especially the FMF. I put that on my stock 86 and got very little gains even after re jetting. Esr would be my second choice because they only make the low to mid pipe for the ATC. I just ordered a new Pro x topend kit from them with mid to top porting. I heard that they pack the most punch for the buck, we'll see!
Old Apr 21, 2005 | 01:15 AM
1BAD250R's Avatar
Default 250R pipes
I ride a trx, but my FMF gold series was incredible on the low end. It was not the best built pipe though, as no matter what I did it never sealed up to my exhaust flange correctly and it always made a mess of my motor. I bought a CT midrange pipe (not sure if they make em for the ATC) with an ESR silencer and it really woke it up in the mid and top ends.
Old Apr 26, 2005 | 05:46 AM
Faster250R's Avatar
Default 250R pipes
JkAss, I don't know if this is still a relevant topic for you (In light of recent events, my heart still bleeds!), but I have a Paul Turner pipe, love it and recommend it! Mine happens to be a High-Rev. I run a CT 310 kit and found that my problem is not the high rev portion as it is pulling the low end of a hill shift. I think for my set up and dune riding/hill racing, (and I have played with all possible combinations of gearing) found I would re-opt for the low-end pull of a pipe. Especially based on the fact that once you get a two stroke in close proximity of the power band she will handle the rest from there as long as you hold the gas on.
