250r Racing Mods
Ok, I recently got an '86 TRX 250r and am planning to race MX. I already have Turf Tamers and Radials, a revalved rear shock, Graydon Proline Nerfs, bumper and grabbar, Race Plastic, renthal bars, etc
I am getting ohlins front shocks as well.
Ok, what I want to know is some fairly cheap engine mods to make it more powerful, I have a 12 tooth front sprocket on the way. I dont think that the CR gasket will work to up compression, the way I understand it the 86 has one anyway. So, what some other thing to help out?
Thanks
Thanks
get a-arms axle swing arm shocks front and rear k&n filter handlebars that are dirt bike style low and motor mods geta wisco piston a heavey duty clutch kit and a cool head and some aftermarket reeds and a boyseen float bowl that is larger than usual and also run 14/37 gearing with 18 inch turfs and get the MSR raptor clutch lever and keep your cables clean get a aftermarket case saver nerfs bars take the air box lid and snorkel off get a prefilter beedlocks on the rear and check the frame for chacks and get them welded up if any and get a good helmet pants jersey chest protector gloves and boots and depending on conditions get the smith roll off goggles if needed kill switch check all the bushings in the a-arms and shocks and stem bushings and take it easy your 1st race dont let the 1st lap adrebaline bet you
I forgot to mention that I already have a Paul Turner pipe and FMF silencer, I have everything I need to race such as jerseys, chest protector, helmet boots, whatever.
I have raced before on my 300ex, but just stepped up to the R last month or so. So I just need some ways basically to up the compression or soemthing to give it more low end power for MX.
Also, why is a new swingarm necessary? I like the one on there right now, what would a new one help?
i ment to get a -1" or -2" (swing arm) for better hook up. The -1" is the same as the 88-89 "R" had (and forward 1" a-arms) sorry to confuse you
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
