250r Racing Mods
Old Sep 30, 2000 | 02:39 PM
rhino99's Avatar
Ok, I recently got an '86 TRX 250r and am planning to race MX. I already have Turf Tamers and Radials, a revalved rear shock, Graydon Proline Nerfs, bumper and grabbar, Race Plastic, renthal bars, etc
I am getting ohlins front shocks as well.
Ok, what I want to know is some fairly cheap engine mods to make it more powerful, I have a 12 tooth front sprocket on the way. I dont think that the CR gasket will work to up compression, the way I understand it the 86 has one anyway. So, what some other thing to help out?
Thanks
Old Sep 30, 2000 | 08:33 PM
87_250R's Avatar
a pipe and silncer would be next then wider a-arms (and forward) and axel then - swing arm
Old Sep 30, 2000 | 08:37 PM
400exalltheway's Avatar
get aftermarket reeds and a bigger carb also. go with the suspension first though
Old Sep 30, 2000 | 08:40 PM
87_250R's Avatar
o ya you will probaly need nerfs and a kill swich to race.
Old Sep 30, 2000 | 09:20 PM
250Race's Avatar
get a-arms axle swing arm shocks front and rear k&n filter handlebars that are dirt bike style low and motor mods geta wisco piston a heavey duty clutch kit and a cool head and some aftermarket reeds and a boyseen float bowl that is larger than usual and also run 14/37 gearing with 18 inch turfs and get the MSR raptor clutch lever and keep your cables clean get a aftermarket case saver nerfs bars take the air box lid and snorkel off get a prefilter beedlocks on the rear and check the frame for chacks and get them welded up if any and get a good helmet pants jersey chest protector gloves and boots and depending on conditions get the smith roll off goggles if needed kill switch check all the bushings in the a-arms and shocks and stem bushings and take it easy your 1st race dont let the 1st lap adrebaline bet you
Old Sep 30, 2000 | 10:43 PM
rhino99's Avatar
I forgot to mention that I already have a Paul Turner pipe and FMF silencer, I have everything I need to race such as jerseys, chest protector, helmet boots, whatever.
I have raced before on my 300ex, but just stepped up to the R last month or so. So I just need some ways basically to up the compression or soemthing to give it more low end power for MX.
Also, why is a new swingarm necessary? I like the one on there right now, what would a new one help?
Old Oct 1, 2000 | 10:34 AM
87_250R's Avatar
i ment to get a -1" or -2" (swing arm) for better hook up. The -1" is the same as the 88-89 "R" had (and forward 1" a-arms) sorry to confuse you
Old Oct 1, 2000 | 07:55 PM
rhino99's Avatar
Thanks for the reply, I didnt know that a shorter swingarm made it hook up better!
Thanks
Old Oct 2, 2000 | 01:27 PM
BUBBAG's Avatar
OH YEAH DUDE, BE SURE TO HAVE GOOD HEALTH INSURANCE
Old Oct 2, 2000 | 02:44 PM
ATVPRO's Avatar
remember when getting oversize a-arms you will need to have the front shocks redone, so it may be wise to get the a- arms and shocks at the same time
Customer Service #1
May 15, 2020 08:46 AM
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Sep 23, 2015 06:23 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
