400 ex axl bearing issues
Old Apr 17, 2005 | 12:22 PM
raptoryfm350's Avatar
Default 400 ex axl bearing issues
I can't seem to keep the water out of my axle bearings causing me to replace them every 4 months. Has anybody else had this problem? What might some solutions be?
Old Apr 17, 2005 | 12:52 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
When you have your axle out, check to make sure that that area on the axle that comes into contact with the seals are smooth. If they are rough they will tear up your seals in a matter of minutes and water will be getting in right away.
If it's roughed up, you would be wise to buy a new axle. That's what I had to do.
Old Apr 17, 2005 | 07:51 PM
My axle is smoothe where you mentioned. I think it's coming in from somewhere else maybe further up on the swingarm. Any other suggestions?
Old Apr 17, 2005 | 08:31 PM
Pirate Biker
Limping Rider!
When you replace your bearings have you had the bearing carrier out? If not, take it out and inspect it. There is no other wat for water to get into your bearings unless the bearing carrier has a crack in it. It is a solid piece of aluminum with the bearings mounted in it and then the seals. No way for water to get into the swingarm and then the carrier unless it's damaged.
Old Apr 18, 2005 | 06:20 PM
NotuRaptor2's Avatar
If you mean when you loosen the bolts to adjust your chain and water runs out, that is normal for a 400ex. The water isn't in your bearings at that point. The water is between the carrier and the swingarm.
The only way for water to get into the axle is through the two seals you mention on each side.
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
